Opinion on cams?
Old Mar 5, 2002 | 10:44 PM
SlickWillie's Avatar
Opinion on cams?
I have an 89 Iroc with a 383 stroker in it and a mini ram intake, aftermarket heads,2.02 1.60's, getting the heads worked in a few weeks. I am not sure on the injectors or the rest of the car or motor, I just bought the car 2 weeks ago w/ a spun main bearing. I am kinda leaning towards the ZZ-9 cam or one of Lingenfelter cams. I am also considering the LT-4 hot cam. What cam and stall convertor would you suggest for the following setup. Thanks in Advance
Old Mar 5, 2002 | 10:52 PM
rezinn's Avatar
What kind of gears are in the rear? Those minirams are high rpm intakes. I'd suggest some pretty low gears and a high stall. How high you want to rev it and where you want power should help to pick a cam.
Old Mar 5, 2002 | 11:02 PM
If i am not mistaken it has 3:45's with a 9 bolt but planning on going with a 10 bolt and 4:10's. Well i guess i am looking for a lot of low end torque but still want it to have respectable hp. Hope this helps
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
masonta
Sep 1, 2015 06:40 PM
