LB9: L98 or S/R Torquer 305?
Old Mar 6, 2002 | 05:19 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm thiking about getting new heads later this summer if I can afford it when I do my cam swap. I was wondering, which of these would be better for my LB9 305? I plan on SLP's medium sized cam, I think it's #31006, Edelbrock Hi-Flo TPI base, SLP runners, and SLP CAI. Maybe a bigger throttle body someday for kicks. And hopefully if I can afford it, it'll all be port matched, and have full SLP exhaust sooner or later. Can anyone recomend a good set of roller rockers to go with these heads also? I wanna keep the stock centerbolt covers cause I just bought a set of chrome plated stock ones...
Old Mar 6, 2002 | 05:55 PM
Ride4ME's Avatar
torquers:
Cheaper
better flow numbers
Old Mar 6, 2002 | 05:57 PM
iroc22's Avatar
Vortecs will give you the most power, next the torquers with their good intake flow #'s and last L98 heads.
Old Mar 6, 2002 | 09:10 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd recomend a set of L30 heads and scroggin's dickey intake.
Old Mar 7, 2002 | 10:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume since you said "port matched" that you're willing to do some die grinder work. That's good, because although the Torquers are good parts, they really need the bowl work to make them do what they are capable of. Do the full SA DIY guidelines job on them, you'll have an excellant set of heads. Center bolt covers, screw-in rocker studs, good valve springs, and exhaust cross-over passages also included in the deal.
L30 heads? Not sure if they exist, but if so, are those 305 Vortec heads? From what I hear, they don't flow so great. L31 heads have 64cc chambers and should be shaved .040" or so to get down to 58cc, meaning shave that $400 base as well.
Stay away from Proform roller rockers. The Summit parts should be fine, though. Comp Pro Magnums would be a more expensive but quite excellent choice.
Old Mar 7, 2002 | 11:54 AM
Steve89GTA's Avatar
How does the World Products heads compare to all of these (58cc chamber)
S
oops, the s/r are the world products aren't they.
lt500r55
Sep 1, 2021 01:30 PM
PestilenceIV
Sep 5, 2015 04:37 PM
masonta
Sep 1, 2015 06:40 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
