stuck temp gauge
Old Mar 6, 2002 | 07:06 PM
PopaPork's Avatar
stuck temp gauge
Hey guys I posted this a few months ago, but didnt get really any break threw ideas......
1) When I start my car my temp needle does the wildest of things. Some times it will jump all the way up an det stuck on the side of the gauge. to try to fix this I bent the gauge so it cant
get stuck
2) some times when I start the car the needle goes down and gets stuck. So I bent the bottom of the guage
3) Some time the needle doesnt move at all.
4) Some times the damn thing works fine.
Anyone know whuts up? I'ved check the connector on the block that is nice n tight, and I also cleaned off any rust or junk that is there, but no help. Do I need a new gauge?
Old Mar 6, 2002 | 08:25 PM
JPrevost's Avatar
Car: 91 Red Sled
My temp guage was doing the exact same thing when it was grounding on my headers along with my o2 sensor wire. That's what I/GM gets for running wires between the block exhaust system. Even my starter solinoid wires are about to fall apart!
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
