What is the compressed height of factory L98 Head Gaskets
Old Apr 23, 2001 | 09:36 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
What is the compressed height of factory L98 Head Gaskets???
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old Apr 23, 2001 | 09:45 PM
Vader's Avatar
Matt,
There have been varying numbers quoted in the past, but my information is that the original gasket compressed thickness was designed at 0.039". I've seen some quoted at 0.041", and some as low as 0.021".
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 23, 2001 | 09:57 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
According to the MMVA (Manufacturers Motor Vehicle Specifications) for 1987 U.S. Passenger Cars, Chevrolet Motor Division, General Motors Corporation, the compressed head gasket thickness for the L98 is 0.021 inches.
Other specs include:
Bore Spacing (cl to cl): 4.40"
Cylinder Block Deck Height: 9.025"
Deck Clearance (minimum): 0.025" below
Minimum Combustion Chamber Total Volume (cm**3): 75.47 with piston at TDC and all components in place torqued to specifications.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited April 23, 2001).]
Old Apr 26, 2001 | 05:39 PM
Matt87GTA's Avatar
Ok, next question..... What is the compressed height of the Felpro # 7733PT-2 Head Gasket?? It is the one that Trick Flow recommends using with their 23* heads so that will be the one I will be using but I cannot find any info on the compressed height of it - not even on the Felpro package??? Any help is appreciated....
Matt
Matt
Old Apr 26, 2001 | 07:01 PM
james_fearn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Matt87GTA:
Matt
</font>
That is the el cheapo gasket at about $15/piece at summit. The better/best gasket is the 1010 that they also list. That is the gasket you see people using on their AFRs and such. The 1010 is about $35/piece.
Do a search under the topic "gasket" or "head gasket" on the TPI and aftermarket review boards.
James
Old Apr 26, 2001 | 08:16 PM
Guest
Guest
Posts: n/a
Matt
</font>
Arent those aluminum heads? Those gaskets shouldnt be used with aluminum heads. And just about every Felpro gasket is .039 compressed or close enough. They do have some others, but thats a good starting point. Thats what the 7733 are.
Old Apr 26, 2001 | 08:57 PM
jaretz28's Avatar
Yeah, remember to use gaskets that corespond to the correct type of heads you have or are buying. The thickness that most professional engine builder use is 0.040" but some crazy people like "Pat Musi" have gone as far as to use 0.015". NO kidding. But stick with the 0.040". If you need less compression use a copper gasket, they are about 0.060" Have a nice day.
Old Apr 26, 2001 | 10:09 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by Willie:
</font>
No wonder my car makes 9.5:1 stock compression!! With a .039 or .041 gasket the compression would suck and then it wouldn't have been 190HP stock!!
Old Apr 26, 2001 | 10:44 PM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by madmax:
Arent those aluminum heads? Those gaskets shouldnt be used with aluminum heads. And just about every Felpro gasket is .039 compressed or close enough. They do have some others, but thats a good starting point. Thats what the 7733 are.</font>
The recommended parts sheet that came with the heads has the 7733PT-2's listed as the head gasket to use for "mild engines". The 1010 is listed for "high output engines up to 4.155" bore (will not indent aluminum heads)" so upon further reading and advice from you folks........... I will use the 1010's. Thanks for the input.
Matt
Old Mar 6, 2002 | 08:15 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
coincidentally, i called felpro earlier today and found that the 7733pt2 gaskets are 4.125 bore and .038 compressed thickness. why is it a bad idea to use these on aluminum heads? i was planning on putting them on my vette l98 w/Al heads because they came with the car.
Old Mar 6, 2002 | 08:37 PM
Guest
Guest
Posts: n/a
The steel fire ring in the 7733's will brinell the aluminum heads. Basically, it will leave a nice, slightly compressed area where the ring from the head gasket touches it. It can cause a combustion leak over time. Get the right gaskets.
Old Mar 6, 2002 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless the factory has changed their assembly parts, I don't recall them ever using a composite head gasket on a factory installation. A factory steel shim head gasket is usually in the .018-.025" range. I have some .018" factory gaskets hanging in the garage.
The composite head gaskets from Felpro are usually .039 or .041"
Old Mar 6, 2002 | 08:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i used the 1010 on my L98 with TF heads.
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
