cheapest place for trick flow 23deg heads
Old Mar 6, 2002 | 10:59 PM
87transam5.7tpi's Avatar
I just wanna know if anybody has any "secret" places where you get em from? summit has them for $999 thanks in advance everybody
Josh
Old Mar 8, 2002 | 12:19 AM
BenDoe91z28's Avatar
check this place out
http://www.goautocenter.com/cylinder_heads.htm
trick flow 23 $800 1.25" spring
Old Mar 8, 2002 | 12:29 AM
or try these
http://www.totalengineairflow.com/pr...head/index.htm
TFS 23°, 1987-95 non-LT1, 1.25" springs (30400005): $875*
TFS 23°, 1987-95 non-LT1, 1.47" springs (30400006): $945*
http://www.bbandtracing.com/
or a cheap place for AFR's(only 200 more than the trick flows in summit)
http://www.users.qwest.net/~zjon/z-r...ads/AFR190.htm
190cc Street Heads, L98 Angle Plug w/heat riser, 74cc 1017* $1210.00
let me know if you research any of these companies, i'm interested in a pair of heads myself
Old Mar 8, 2002 | 09:43 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Summit OWNS Trick Flow.
dutch930
Sep 11, 2015 06:58 AM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
