Best Way?
Old Mar 9, 2002 | 01:19 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Best Way?
What is the best and easiest way to swap in a new cam? Is it possible to remove the front bumber and the radiator do the swap? Has anybody done it this way or another way? Or do i have to pull the motor? Which is easiest?
Old Mar 9, 2002 | 01:24 AM
ronterry's Avatar
Car: '94 Corvette
If you don't have an AC condensor, you can do it, and hell yea it's easier then having to remove or lift the motor.
I know on my 2nd gen Z-28, all I had to do was remove the radiator, and condensor.
Ron
Old Mar 9, 2002 | 12:12 PM
Vader's Avatar
You only need 22¼" in front of the machined timing cover surface of the block to get it out/in.
Old Mar 11, 2002 | 01:47 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Has anybody done it this way before?
Old Mar 11, 2002 | 02:38 PM
82camaro's Avatar
Car: 82 camaro SC
Yes it can be done. It's much easier than pulling the motor. You just have to remove enough stuff in front of the engine to slide it out.
