is this a gm or camaro thing or what? dang power steering leak!!
Old Mar 10, 2002 | 12:47 AM
89Irocz23's Avatar
Well I have noticed on camaros that the power steering seems to leak or something. Well I never knew mine leaked til I was under it today I saw it all over that bracked and bottom radiator hose? How do I fix this or do I not need to worry about it? Mine fluid level hasnt really changed much so.
Old Mar 10, 2002 | 03:57 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I've never seen a hydraulic system that didn't leak somewhere. The PS pumps on our cars an most GMs from that era have the connections for the lines between the pump body and the pulley, so you can't even check them, much less work on them without removing the whole system. Also, if your fluid level is above the 'full' line at all, it will vent through the cap, covering the whole side of your engine with a film of PS fluid.
What can I say, Welcome to the Wonderful World of General Motors.
Old Mar 10, 2002 | 06:45 AM
KeithO's Avatar
My power steering fluid leaks out of the filler cap, particularly under extreme use (autox and road racing). This is (unfortunately) normal for 3rd and 4th gens. I keep a bottle of power steering fluid around and top it up everytime I check the oil.
That's life.
Old Mar 10, 2002 | 07:43 AM
Hulk0202's Avatar
Check the high pressure hose. I've had a bunch of then leak where the meatal and the rubber hose meet.
Old Mar 10, 2002 | 11:54 AM
StangKiller's Avatar
Maybe I'm the only one but mine does not leak at all, I flushed it once a few years ago just because it had 90,000 miles on it and had never been topped off and it was still full, now 40,000 miles later it's still full.
Old Mar 10, 2002 | 09:05 PM
89Irocz23's Avatar
well i cant see really where its coming from but I notice fluid that rna down my radiator hose which is only like 1 month old. Also cna I spray some kind of degresser under there ot clena it all up. This is a newly built engine I dunno what it is but I like my engine clean. I know it doesnt matter, but still
Old Mar 10, 2002 | 09:15 PM
RB's84camaroF-41's Avatar
mine doesnt leak
Old Mar 10, 2002 | 09:44 PM
Hulk0202's Avatar
I had the same problem. Dry everything off, start the car and turn the wheel a few times or drive around a little then check for leaks.
Old Mar 11, 2002 | 11:58 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
mine leaked, and i couldnt stand it. 215 dollars later the shop fixed it.
Old Mar 11, 2002 | 02:39 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
i replaced my entire ps system with rebuilt components and new hoses from autozone for $250,no leaks,very smooth and responsive and no play...until I ate a curb a 60mph....that's another story.
Old Mar 11, 2002 | 09:53 PM
87 iroc L98's Avatar
PS FIX
a couple of years, a buddy of mine bought a 82 camaro with no engine, so he jamed in a 327sb that came out of a 67 Camaro
with no PS at all, so he took some junkyard PS hoses and turned the car to manual steering, he just rerouted the hoses into one another.
Vance
Old Mar 17, 2002 | 12:27 AM
firbird's Avatar
mine is leaking right now and pissing me off, there is a pin ***** in the high pressure tubing and when ever i floor it and bring up the rpms it comes out and i need to replace it, think i will just get a manuel stearing box
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reborn756
Sep 4, 2015 03:42 AM
Bob88GTA
Aug 18, 2015 03:31 PM
