RPM Jumping
Old Mar 13, 2002 | 12:59 AM
Agent-Z28's Avatar
RPM Jumping
OK I rebiult my engin last year and just about a month ago it the RMPs started to jump around between 8 and 1200 while it idles and it flucuates that much while driving, so I put on a new cap and rotor, fuel filter, and plug wires. When I pulled the plugs it looked like the engine was running lean however it smells like it runs rich doe!!!!! I checked the fuel pressure it is steady at 42 psi. Is there any way to check the coil output? any other suggestions?
I have a 305 TPI
Old Mar 13, 2002 | 02:52 PM
Damon's Avatar
Check for vacuum leaks. Double check vacuum hose routing. Very common reason for a floaty idle
camaronils
Sep 20, 2015 02:57 PM
wisemanz28
Sep 20, 2015 01:26 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Stroopwafel
Sep 11, 2015 06:38 AM
