Backfiring, help.
Old Mar 14, 2002 | 05:06 PM
Mike89GTA's Avatar
Backfiring, help.
I took my car to get it inspected today and it passed. When I was driving home it started backfiring. I checked the spark plug wires and they're all firing (got shocked in the process, wow!). It runs very smooth at idle, but if I rev it at all it backfires. I noticed an exhaust leak within the past 2 weeks that seemed to be getting worse. It sounded like the driver side header collector. But now I can't hear it. I hope it's not like a burned valve or something
Thanks,
Mike89GTA
Old Mar 14, 2002 | 05:52 PM
Mike89GTA's Avatar
btw, the exhaust smells like gasoline which leads me to believe a cylinder isn't firing. But I checked all the wires using a timing gun and they're all working. Would the timing light blink even if hte spark plug wasn't working but the electricity was just going to the ground or something?
Old Mar 14, 2002 | 08:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If the spark plug gap became bridged by deposits it wouldnt fire.
Old Mar 15, 2002 | 08:48 AM
Mike89GTA's Avatar
I just unplugged each spark plug wire and it still does it. I noticed a vacuum hose is broken. Would this cause backfiring? It's the vacuum hose right by the distributor, here's a pic.
http://66.61.58.118/stuff/hose.jpg
Here's a video of the backfire..
http://66.61.58.118/stuff/backfire.avi
dimented24x7: The spark plugs are relatively new so it's probably not that.
Old Mar 15, 2002 | 09:45 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is it backfiring thru the exhaust or in the intake? Exhaust could be due to the leak. Intake would be if you're running lean or if the timing is some how off. If you have a vacuum leak, I would think the car would idle a little rough.
racereese
Oct 3, 2015 03:46 PM
Numbah-1
Oct 2, 2015 08:27 AM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
