going faster at the dragstrip
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
I heard from someone that disconnecting your alternator can give you a gain of 3 to 4 tenths of second in your ET. I don't now if this is true, but if any of you have ever tried this before and gained some time, get back to me.
1988 Iroc-Z Z28
350 tpi
700r-4 tranny with B&M shift kit
1988 Iroc-Z Z28
350 tpi
Transmission: 4L80E/4L80E
You might gain a hundreth from the reduced load on the engine.
You can lose a few tenths from the reduced voltage to computer-controlled, voltage-sensitive items.
Keep the belt on.
Keep the belt on.
Car: 2006 Silverado 1500
Engine: 5.3L
you may quite possibly pick up a tenth or two if you are running a good battery, but with a not so good battery your defeating your purpose.
no green
Mar 3, 2016 05:19 PM
