Exuse my ignorence but i need help on removine the computer!!!
Old Mar 16, 2002 | 09:21 PM
ThirdGen Stoner's Avatar
I would LOVE to know exactly what the computer/ECM controled on my '86 Z-28! I want to totaly simplify it. I need to know if I will lose A/C or heat. I need to know EVERYTHING!
I know I need vacuum edvance dist., non-cc carb, and torque lockup switch.
Is there anything else??!! Will I lose anything??
ANY info would be GREATLY appreciated!!!!!!
Old Mar 17, 2002 | 12:02 AM
Monkeyballs's Avatar
easiest way would be to buy an older car with no computer. There is too much to switch to take the computer out to make it worth the time/money.
Old Mar 17, 2002 | 03:11 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Re: Exuse my ignorence but i need help on removine the computer!!!
The computer controls the fuel mixture, spark curves, and the emissions control equipment. You won't lose a/c or heat but your car will lose its emissions "legality". THere's a ton of crap to remove along with the computer stuff itself and said above its not worth the hassle.
Old Mar 17, 2002 | 09:02 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You will for sure need a pair of wire cutters... after my swap from 2.8 to 327 I have a total of 7 wires connected. compared to 700..:lala:
Old Mar 17, 2002 | 11:43 AM
Well, I do not have to deal with emmisions here so thats out of the question.
The only things you have to remove is the wiring harness. And the smog crap. Thats not a ton. And plus theres not a motor in the car (undergoing a swap) so it will be easier. Ive already removed the ECM and all the wires are just sitting in the engine bay.
I think thats all you have to remove anyway
Old Mar 17, 2002 | 02:14 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I unplugged my computer and pulled the wires through the fender then just cut every single wire that went into the engine from the computer. I honestly had no clue what I was doing at first and prayed my car would work. It did ....I gotta scan the before/during/after pictures.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
