Problem with engine install
Old Mar 18, 2002 | 09:19 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Ok, heres the problem...
We just put in my 355 engine and hooked everything up and when you turn the key the fan and fuel pump comes on but the car doesnt fire. We can start the car however now by running a line between the starter wire and and the battery wire I believe with a push button in the dash. That takes care of starting the car but the gauges like speedo and tach don't work??? Any suggestions? Thanks
Old Mar 18, 2002 | 10:32 AM
Vader's Avatar
Go back to the starter and make sure the fusible links on the purple wires are intact. Make sure the ignition switch is operating all the contacts correctly. You should have power to all the orange wires when the switch is turned to RUN.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
