need help
Old Mar 18, 2002 | 08:26 PM
jeffz28's Avatar
need help
i can't find the part number of my cooling fan temp switch on my 305 4bbl. vin G the only number on it is dr562 2256 but i can' t find the manufacturer to get a new one do you know who made this and where i can get a new one pep boys told me it was a knock sensor but the chilton and the antifreeze that came out of the hole after i took it out disagree i think
Old Mar 18, 2002 | 08:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Was it in the cyl. head b/w the two rear most spark plugs? If it was there than its the fan switch.
Old Mar 19, 2002 | 09:35 AM
Vader's Avatar
Jeff,
The detonation sensor is threaded into the cooling jacket as well, but along the lower edge of the case casting, not in the head.
Just a hint: The "DR" in the part number you quoted is likely "Delco-Remy". Before they were known as "AC-Delco" and now "Delphi Automotive" they were called "Delco-Remy" for about 70 years.
If the sensor you removed is about 1-3/4" in diameter and has a rounded outer edge, it is probably the detonation (knock) sensor. If it is about 1" in diameter and has a modified 12-point perimeter and one wire, it is probably a temperature sensor.
You can get an aftermarket sensor in either case, and most parts houses should have a cross reference that lists the part you need.
