Harmonic Balancer
Old Mar 19, 2002 | 12:56 PM
ISR_NITRO's Avatar
Harmonic Balancer
ok so i fully rebuilt my engine 350chevy sb and im putting the harmonic balancer on and its really stiff fitting it into the timing chain cover hole like really stiff i used a rubber hammer to get it on most of the way but got scared of braking something just wanted to know if thats normal??? i replaced all my gaskets and such so i dont know help???
Old Mar 19, 2002 | 01:05 PM
rezinn's Avatar
You can do it that way if you're careful, but there is a tool to assist you that threads into the crank. You can rent it at most auto parts stores.
Old Mar 19, 2002 | 05:49 PM
ede's Avatar
ede
it won't help the balancer go on any easier but put some grease or assembly lube on the crank seal or there's a good chance you'll fry it when you start the engine.
Old Mar 20, 2002 | 08:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't use the center bolt from the crankshaft to draw the balancer on, you can screw up the threads in the snout of the crank; get the tool ede mentioned. Also, make sure you have the balancer lined up with the keyway properly, and that it's perfectly straight with the end of the crank, and not cocked sideways a bit.
Old Mar 20, 2002 | 10:34 AM
Vader's Avatar
NITRO,
Incidentally, that "tool" is a 7/16-20 threaded rod, about 5" long, with a mating nut and washer. You can use a large socket as the drift, or try the large washer that normally holds the HB in place behind the factory bolt.
Thread the rod into the crank snout, start the balancer hub by hand making sure to align the keyways, assemble on the socket/washer/nut combo, and start turning the nut.
Ede makes an excellent point about prelubricating the seal.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
