Rust in water
Old Mar 19, 2002 | 03:20 PM
dtpmike's Avatar
Rust in water
How can I fix this. Ive flushed it out a few times, but eventually it comes back. I have an autozone radiator and waterpump.
I use about 30%-50% antifreeze with the water. Once for about 2 weeks I used straight water but then added antifreeze.
Old Mar 19, 2002 | 03:58 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
if you going to run straight water you have to run redline water wetter in it to prevent corrosion of the passages..........and never ever EVER run tap water.........distilled only, dont want all those minerals in your motor............
Old Mar 19, 2002 | 04:02 PM
rezinn's Avatar
If it rusted before your water pump and engine probably both have plenty of rust built up now. You have to use some sort of flush to clean it out, and then make sure you run a good amount of coolant. Switching to the newer dexcool would help.
Hellraiser's Avatar
In all honesty, where you get the water doesnt matter. I wouldn't bother with distilled water, repair shops don't use it and you dont need to either. However you may want to try running some prestone (or other brand) radiator flush solvent throught there, then drain and try again...
Old Mar 20, 2002 | 08:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I dunno; I always use tap, and whenever I pull off a hose, it's always filled at the end with white crusty mineral deposits. I hear those can even take out a water pump front seal! 'Course, I haven't bothered to pick up distilled water yet, but I think if we have access to it, we should definately use it...
Old Mar 20, 2002 | 06:30 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
correct me if i am wrong but wont distilled water still rust eventually?
Old Mar 20, 2002 | 06:59 PM
wasp's Avatar
not with water wetter in it ............run tap water if ya want............learn the hard way
sheachopper
Jul 31, 2019 11:27 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tcflint
Sep 27, 2015 05:58 PM
