can somone explain this?
Old Mar 19, 2002 | 04:16 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
ok, we all know the tensioner pulley is on the same bracket as the ac........i was wondering the same thing......"how do i remove the bracket and still keep the belt tensioner pulley".........i just read a few posts of people saying use gm part # 10055890 ac delete pulley................i did some searching............this is what i found.....http://www.gmpartsdirect.com/results.cfm ........is this just a plain old pulley? does it come with the tensioner? or is the tensioner eliminated? and how does it install on motor?
Old Mar 19, 2002 | 04:18 PM
wasp's Avatar
oooooooops put 10055890 in that search box on top........it comes up as a water pump pulley..............
Old Mar 20, 2002 | 03:19 PM
wasp's Avatar
i wish somone would reply to my posts..........
Old Mar 20, 2002 | 03:32 PM
rezinn's Avatar
Have some patience, man.
The pulley is just a pulley that replaces the compressor. You leave the tensioner and smog pump on. 10055890 is the correct number.
Old Mar 20, 2002 | 05:40 PM
Omar's Avatar
Yeah, the bracket itself stays. You are just replacing the AC compressor with a pulley.
Old Mar 20, 2002 | 05:59 PM
wasp's Avatar
i think 50 views is patience enuff,......thankyou for your replys........see i thought the bracket went as well......is there a way to do that? that bracket looks like it weighs a ton........do the compressor and related components weigh enuff to make it worth the trouble to remove ? will just a pulley and not an ac compressor free up few horses or is it very minimal?
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Cacike
Aug 27, 2015 05:10 PM
