I finally found that my throttle is sticking!
Old Mar 19, 2002 | 09:20 PM
AFRO IROC Z's Avatar
I found that my throttle is sticking and was wondering if you can replace the spring with a new one because i think the old one is worn out. Can i get just the spring or no? Thanks
Old Mar 19, 2002 | 09:28 PM
jfox55's Avatar
Just go to the junk yard, you could probalbly pick one up for a dollar. When mine broke, I didn't have time to go to the junk yard. I went to wall mart and bought one of the springs for a screen door return, cut it down and bent the ends worked fine. The only reason I switched it out was because I got one for free. The one from the spring door was very strong, great return.Good Luck Jason Fox:rockon: :rockon: :rockon:
Old Mar 19, 2002 | 10:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Of course, changing the spring is about one of the easiest things. I've had experience of a faulty spring sticking, that was scary.
Old Mar 20, 2002 | 10:35 AM
mattRS's Avatar
where is this spring? i am having trouble with my throttle stickin too, and i think this may be it
Old Mar 20, 2002 | 09:59 PM
Vader's Avatar
https://www.thirdgen.org/techbb2/sho...threadid=93445
Old Mar 21, 2002 | 12:21 PM
xxwarrior36xx's Avatar
My caes is probably the most messed up but if that doesn't work you might want to look into this. My cruise control would activate and stick my pedal downa and wouldn't disengage it. I had to tear it out of my car....I hope this sin't it for you it is an extreme but if nothing else works try it out.
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
