Wheels and Tires strange occurance...
Old Mar 21, 2002 | 03:40 PM
Teal Shark's Avatar
Car: 1982 Camaro Z-28
Engine: 406 SBC
Transmission: TH350 stage 2 shift kit
Axle/Gears: 3:73
A strange thing happened to me on St. Paddy's day on the way to work. I drove down my driveway and around a left corner when my tire rolled off the wheel towards the car. No popping or tearing. Just rolled off. My car is lowered so I couldn't even get my foot under the car let alone a jack so I had it towed across the street where they could look at it at the garage. Guys said wheel's fine, tire's fine, no damage. It just "slipped off". Has anyone ever heard of a tire just slipping off like that? The wheels/tires were in storage for awhile, and pressure was checked a day and a half before and was good. The garage said they resealed it back on, and it just came away from the bead. Go figure. Any input is appreciated. Thanks. -TS
Old Mar 21, 2002 | 10:04 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
I had it happen on one of our old vans when it slid in to a curb in the snow at about 30mph; but just from going around a corner?
Unless you are running an excessivley wide or narrow tire for the rim width, and/or super low air pressure, the tire shouldn't have come off, unless your rim doesn't have much of a lip on it. According to your sig, you are running 235s on 15x7s, but that sounds okay to me. The only thing I can think of is that the tires got a little stiff during storage, and they couldnt flex like they're supposed to.
You didn't get your tires from this guy, did you? ->:lala:
Just kidding....
Old Mar 21, 2002 | 10:28 PM
Vader's Avatar
Teal,
A 60-series tire should have enough sidewall flex to prevent bead separation. What was the tire pressure? (I KNOW it was zero after the tire came off!) I would expect that you would run those at about 27-28 front and 24-26 rear at a minimum.
Old Mar 22, 2002 | 12:33 AM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
tire probs
Just kidding....
Yep no hitting a curb, NOTHING. The tires are: 195 60 R15 (on my
Nitros, not the Prostars)
NOT excessively wide or narrow, really...I am thinking maybe stiff and dry from storage. Thanks for you input!
-TS
Old Mar 22, 2002 | 12:35 AM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
Originally posted by Vader
Teal,
You would think a 60 series would be fine. I'm running 195 60 R15s on my nitros... Tire pressure was around 28 psi if I remember. Freaky or what eh? Thanks for your input! -TS
Old Mar 24, 2002 | 09:41 PM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
tire separation update
Well if things could go any worse, they have. After having my tire remounted and sealed, it lasted maybe, 2 minutes. Same thing happened, same tire. I am *$#ing sick of this and I am just putting my old prostars (dunlop gt qualifiers) back on until I get brand new tires for the nitros next year. Probably need to have the wheel checked, I have suspicions there is something wrong with it... Any suggestions on how to jack up a lowered car when you get a flat? Man I HATE having to call a tow for a freaking flat. My 2 1/2 tonne jack WILL NOT fit under the car when the tire is flat. We ended up jacking up the back, putting it on a block, then attempting to jack the front. What a freak show. Anyways she now has 3 nitros and one prostar until tomorrow when it is warm enough to finish the job. Glad I don't have a LOW ricecar with extreme low profile tires, this would be an even BIGGER mess. Thanks for all you input. -TS
Old Mar 24, 2002 | 09:57 PM
SpeedCat86's Avatar
Wow, man, that realy sucks...........
There must be some kind of cosmic forces opposed to you having those tires. (Maybe they just like Pro-Stars )
Maybe it's time for new tires.
As far a jacking goes...............The stock jack works pretty well, if all you're doing is changing tires.
Old Mar 24, 2002 | 10:05 PM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
I wish I had the stock jack. My car is an ex dragster which had all the interior stripped and the battery relocated in the back too, hence no jack etc. Yep, it's back to the Pro Stars I guess. (Not like I don't LOVE them) New tires for next season! Time to buckle pavement in my fatties! -TS
Old Mar 24, 2002 | 11:08 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Run the car up on a couple of boards until you can get the jack under it. Just stair step the boards so the car keeps getting higher. If a 2X doesnt fit use 1 in stock.
Old Mar 25, 2002 | 02:39 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
happened to me twice. it is most likely improper lug nuts tightening. at least mine were. not tight enough. thought i would have learned the first time
Old Mar 25, 2002 | 03:26 PM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
Man that is a GREAT idea. I will keep some 2X handy, thanx for the input!
Old Nov 23, 2005 | 10:57 PM
Teal Shark's Avatar
Engine: 406 SBC
Axle/Gears: 3:73
tire probs
I bought the tires and rims as a pkg. A guy I showed them to said the tire was too narrow for the wheel, case solved. I sold the lot of them. I am sticking to my new combo. Mickey Thompson Drag Radials and my Prostars.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
