Accel Super Coil
Old Mar 21, 2002 | 11:11 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Accel Super Coil
Ok....
I have heard that the Accel Super Coil that fits on top of your distributor cap is known for melting the cap...is this truly the case? Has anyone experienced this happening?? I have an opportunity to purchase one, but I am hesitant if this is the case...I dont need more problems...especially my cap melting....opinions? Suggestions?
Old Mar 21, 2002 | 11:19 PM
Swapmaster's Avatar
I have never heard that one before. I ran one for a couple of
years and never had a problem.
Old Mar 21, 2002 | 11:31 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Hmmm.....i wanna hear more experiences/opinions....b/c i have talked to several people, and they said its bad news....I'd like to have it....but I'd like to keep my cap from melting and me getting stuck out on RT. 380 in the Poconos or something....
Old Mar 22, 2002 | 12:24 AM
Swapmaster's Avatar
Accell used to make a cap that had a coil wire lead in the center
for using a coil mounted on the firewall. I had one a long long
time ago, (20 years ago) something like that may ease your mind.
Old Mar 22, 2002 | 12:28 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
That does ease my mind a bit...I just dont want to go wrong with this....its a pain in the ***** soemtimes getting this thing to run right...I just dont want things going worse than they are...
Old Mar 22, 2002 | 12:43 AM
Swapmaster's Avatar
Check out the Accell web site or hit a local parts store, they
should be able to get you something.
Old Mar 22, 2002 | 12:49 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
I work at a local parts store
Old Mar 22, 2002 | 01:15 AM
Swapmaster's Avatar
Then WTF, order yourself something up.
Old Mar 22, 2002 | 02:07 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've had my Accel HEI Supercoil for years and it hasn't melted.
Old Mar 22, 2002 | 02:25 AM
ronterry's Avatar
Car: '94 Corvette
I've never had an Accel coil melt my cap either, and that goes the same for the MSD in-cap coil also. I used both stock caps, and Accel caps. Currently running a Accel cap with MSD HO Coil , Accel 300+ race wires, and MSD 6AL.
It sounds like those guys with melted cap must of had some sort of resistance bottle neck, like cheap 7mm wires or something ?
Ron
Old Mar 22, 2002 | 11:36 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Well, ordering something for myself wont answer the question of if it will melt the cap or not...but it seems like everyone one is saying no....i have Xact brand wires on the car now....8mm....(OE replacements).....but if everyone's experience has been good with them, then i'll go for it...anyone see any performance gains from it? or any benefits???
Old Mar 22, 2002 | 12:05 PM
Swapmaster's Avatar
The stock HEI coil runs out of juice at about 5000rpm.
The Accell will not.
Old Mar 22, 2002 | 01:28 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I had a problem with the stock coil about 5 years ago, anything above 5000 rpms it would cut out. Put the Accel piece in, not a problem since. Theres a testimonial for ya.
Old Mar 24, 2002 | 09:25 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
I guess maybe i should go for it then. Thanks everyone.
Old Mar 24, 2002 | 09:56 PM
fattie92's Avatar
can someone explain how and y this happens,,, and why the super coil is better and how it does want it does?? i was thinkin bout buying one too... but what dif will it make on my performance??
Old Mar 24, 2002 | 10:33 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
There are three options for Accel HEI coils. There is a small coil that goes under the stock cover, the big, round grey coil that replaces the top cover (Supercoil) and a replacement cap that lets you use a 'conventional' external coil
There are a couple other in-cap coils from a number of mfgrs.....
Mallory also makes a 'big' style HEI coil
MSD, Jacobs and Proform make a remote coil adapter.
I have the big round Accel Supercoil, have had it for 3 years now. It made a small but noticible difference, especially with 4 people in the car.
It's a good cheap, quick mod you will be able to feel the difference.
Old Mar 25, 2002 | 12:14 AM
poncho9789's Avatar
A performance coil will normally give you a little more spark to open the gap up on your plugs and will have enough energy in the coil to provide spark for higher rpm operation.
Old Mar 25, 2002 | 03:03 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
are there any negatives to using the super coil? I have one on my IROC and found that the plugs wore out really quickly last time 'round/ The electrodes seem to wear real quick. Anyone else notice this?
Old Mar 25, 2002 | 04:28 PM
poncho9789's Avatar
Your spark plugs can wear faster due to the extra voltage going to them.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Dragonsys
Sep 25, 2015 03:51 PM
