1986 LG4 gooseneck
Old Mar 24, 2002 | 07:56 PM
karfreek's Avatar
1986 LG4 gooseneck
On a 1986 LG4 there are 2 ports on the gooseneck, one that is a vaccum port the other that looks electrical. What would the effect of removing these from the gooseneck to use an aftermarket chrome gooseneck?
Jay
Old Mar 24, 2002 | 09:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm guessing you mean the T'stat housing? If so (keep in mind I've never seen a LG4 though), what you're referring to is probably the thermal vacuum switch.
Check your emissions routing label under the hood, and you should be able to track down what it does/goes to.
Once you figure that out, you can decide from there.
Old Mar 24, 2002 | 11:02 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
One of the wires that leads from the thermostat housing to the carburator senses the temp of the coolant and tells the carb how much of a gas shot is needed, when the engine is cold. You will want to keep that
Old Mar 25, 2002 | 06:12 AM
karfreek's Avatar
On this application the origional carb & emissions equips is removed.
Jay
Old Mar 25, 2002 | 12:53 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
In the stock setup:
The electrical connector is the coolant temperature sensor for the ECM. If you don't have an ECM, you don't need it.
The vacuum connector is the Thermal Vacuum Switch for the flapper valve located in the exhaust. It's part of the EFE system. If you don't have the flapper in the exhaust any more, pull the thing and plug the port on the carb. If you DO have the valve, you'll either need to retain it (find another hole in the coolant jacket) or bypass the switch and run manifold vacuum straight to the flapper valve (that should keep it open whenever the car is running).
Old Mar 25, 2002 | 04:30 PM
Engine: 305-4v
Originally posted by 99Hawk120
In the stock setup:
My 86 Camaro is Canadian and it has no computer gear at all--period.
Yet it still has the wire from the thermostat to the front top of the carb.
Is this the sensor you are speaking of?
If so, how do you explain its presence on my non-cc car?
Old Mar 26, 2002 | 07:58 AM
99Hawk120's Avatar
Odd, I've never seen that. I suspect it's a Canadian-only thing.
Anyhow, the CTS for the ECM is a two-wire connector that disappears into the wiring harness. Is the one you're talking about two wires?
Old Mar 26, 2002 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The vacuum connector is the Thermal Vacuum Switch for the flapper valve located in the exhaust....If you DO have the valve, you'll either need to retain it (find another hole in the coolant jacket) or bypass the switch and run manifold vacuum straight to the flapper valve (that should keep it open whenever the car is running).
Vacuum closes the EFE valve. You don't want constant vacuum on it.
Old Mar 26, 2002 | 02:04 PM
99Hawk120's Avatar
I stand corrected. I don't have EFE on my car, so I just assumed (obviously incorrectly) the temperature switch worked the other way.
SRKLEGIN
Oct 29, 2015 06:38 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Springster
Sep 13, 2015 01:38 PM
Magman
Sep 12, 2015 11:55 PM
