Toubleshooting one wire O2 sensor
Old Mar 25, 2002 | 12:00 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
How do you check a one wire O2 sensor? The book says "Connect and analog voltmeter between the oxygen sensor electrical connector and ground." Another place in the book says " Connect a voltmeter between the sensor side terminal and ground." According to the book I am looking for voltage, but how do I get voltage from an oxygen sensor with one wire? I did get .2 volts when reading the connector on the car side, but on the exhaust side, nothing. I know this is probably a stupid question, but I am really confused.
Thanks,
Mark
Old Mar 25, 2002 | 04:10 PM
ede's Avatar
ede
you need digital not analog, connect lead to the single wire and ground the other, you then read the voltage it puts out, an O2 senser is a voltage generator. check your book for the correct voltage value, i think it's something like .8 volt
Old Mar 25, 2002 | 05:28 PM
Car: 1986 IROC
O.K., thanks for the help! I didn't know that it made its own voltage and I guess that is how I got confused. The book says it will vary from 0.0-0.8, I read 0.0 and it didn't vary. The car was running VERY rich for a couple of months, I fixed that problem (I think) so would no voltage at all mean that the oxygen sensor is bad now? The inside of the tailpipe is VERY nasty with black soot.
THANKS!
Mark
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
dbrochard
Sep 19, 2015 08:13 PM
