need help! got error code 43
Old Mar 26, 2002 | 01:24 AM
gmeternal's Avatar
i was told it is a knock sensor! what does that do? and do i need to change it now or can it hold for a bit! other words will it hurt the car to run on it? lol broke right now!
Old Mar 26, 2002 | 12:27 PM
Vader's Avatar
eternal,
You were told correctly. The detonation (knock) sensor is supposed to detect preignition or spark knock and is there to protect the engine from destroying itself from excesive timing advance. The error code is for a problem with the sensor signal. It may just be disconnected of have poor connections. The sensor is near the starter on the lower right side of the engine, threaded into the cylinder case. You can unplug and inspect the electrical connectiony for corrosion, damage, etc. Without a functioning sensor, the ECM will revert to base timing tables and not advance the ingition timing much at all. You will lose performance and fuel mileage until this is repaired, but it shouldn't do any damage. If for some reason the ignition timing does get advanced, you will no longer have the automatic protection of the sensor, however, and will risk damage from detonation. At least check the connections for now.
Old Mar 26, 2002 | 12:36 PM
gmeternal's Avatar
re
thanks i will try that!
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
