small block ID
Old Mar 27, 2002 | 01:10 AM
islandcamaro's Avatar
small block ID
How can I find out the c.i. of a small block. going 350 hunting so I need to know how to tell the difference. Are there special things to look out for, casting numbers or whatever. Where do I find them? Any way to tell if its a 4bolt or 2bolt without dropping the pan? Help very much appreciated.
Thanks peoples
Old Mar 27, 2002 | 05:26 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Start here...www.mortec.com
bye the way, dont go through all the work of the swap for a 305, get a 350 and be happy
Old Mar 28, 2002 | 08:28 AM
Vader's Avatar
Unfortunately, the casting number doesn't always define whther it is a 2- or 4-bolt main engine. some cases were cast with the same cores and built as either 2- or 4-bolt, so you alomst have to look in the pan.
You'll have better luck getting a 4-bolt from a medium truck than a passenger car.
Old Mar 28, 2002 | 08:50 AM
Swapmaster's Avatar
If you are going for a tuned port engine. Look behind the drivers cylinder head on the flat part of the block and it will say either 5.0L or 5.8L casted right into the block. They will all be 2 bolt mains but you don't need 4 bolts to get into the 13's or 12's anyway.
Old Mar 28, 2002 | 12:50 PM
Stroked-Z's Avatar
4-bolts are always better IMO for extra added insurance.
Unless you get a 2-bolt and convert it to 4 bolt with splayed caps, if you can, try and get a 4-bolt block.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
