wierd buzzing noise from underhood
Old Mar 27, 2002 | 04:47 PM
Joshua Leslie's Avatar
hey all
I have an 89 T/A, originally a 305 TBI, I took al that off and dropped in a carb. 350.
I have about 9000 miles on it and today I started hearing a loud electirical type buzzing noise.
I located where it was coming from, and it is some sort of relay on the drivers side firewall.
I dont think its the fuel pump, cuz I use a Holley external pump.
There are 2 or 3 relay, which are to the drivers side of the brake vacum booster, the relay in question is all the way to the drivers side..what is it?
Old Mar 27, 2002 | 05:30 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Being an original TBI car, I'd imagine you should only have 2 relays on your firewall. Fan and fuel pump. You'll also have flatter thing, thats the ESC module. I'm not sure if thats where it is on a TBI car or not though.
I'd amke sure your fan works. Then unplug the buzzing relay. Then see if it still works. If not replace the annoying buzzing relay, prolly abut to die. If the fan doesn't work i'd say the buzzer is your fan relay, and it's dead.
Old Mar 28, 2002 | 09:08 AM
Vader's Avatar
What color wires are connected to the relay?
db057
Jan 10, 2020 08:55 PM
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
