Can someone run a few cams through desktop dyno for me?
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Ok, It's between these three cams. Here's my motor so far: Stock LT1 bottom end, LT1 intake (but using batch fire injection), CR is between 10.5-11.0, and Flow numbers on the heads are:
i.200" 135.0
i.300" 201.0
i.400" 249.0
i.500" 275.0
i.600" 280.0
e.200" 110.0
e.300" 157.0
e.400" 180.0
e.500" 195.0
e.600" 208.0
The three cams I'm looking at are these:
LPE219 cam: 219/219 .560"/.560" 112LSA
CC306 cam: 230/244 .544"/.576" 112LSA
GTP 6 cam: 235/242 .568"/.592" 114LSA
Also can you tell me what the powerband of these cams should be about? Thanks
i.200" 135.0
i.300" 201.0
i.400" 249.0
i.500" 275.0
i.600" 280.0
e.200" 110.0
e.300" 157.0
e.400" 180.0
e.500" 195.0
e.600" 208.0
intake centerline
i need the intake centerline degrees also.it might the same as the lsa.or if u have the exact degrees of openings(btdc,abdc etc).what kind of lifter(hydraulic,solid,roller)
Fast355
Dec 2, 2016 06:33 PM
