starting problems
starting problems
when i start it up with the key, no problem at all.. fires right up.. however.. i just installed a remote start, and all that does is crank it.. now i dont hear the fuel pump "whirring" when the remote start engages, so i hooked up the second ignition output of the remote start to the fuel pump.. if i do that, the fuel pump "whirrs" and the engine cranks, but.. it still doesnt fire up.. am i missing somehting? the solenoid is getting 12v, that *should* be all the engine needs to start....... right? please lemme know if im missing something
i elected to use the voltage sense rather than the rpms to let the remote start know if the engine was started or not.. it shouldn't make too much of a diff tho..
the main question i have is basically.. what does it take to start the engine? if the only thing you do is put +12v to the solenoid on the starter, should it fire up?
92camaroJoe
Aug 13, 2015 06:07 AM
