Question about bearing sizes?
Old Mar 29, 2002 | 01:33 AM
86305's Avatar
I am extremely confused on this. I'm looking at a rebuild kit for my dads 350 in his truck. Well the website lets yo select the bearing size. It has standard, .030, .020, 0.010, and 0.001. And its the same way for the rod bearings. Can someon please explain this to me.
I would really appreciate it.
Old Mar 29, 2002 | 01:57 AM
Blackened's Avatar
I wouldn't attempt a rebuild if you don't understand this simple concept. But let me explain anyway.
When an engine gets "rebuilt" most of time it's necessary for the machine shop to grind the crank down by removing material in order to get the surface nice and smooth again just like was new. Well since you remove material, you will need a different size bearing. If the machine shop cuts the crank .010 under, then you need a 0.010 bearing and so on... Same thing with the rods. If everything is left stock and no griding was done then go with STD (standard) bearings.
Old Mar 29, 2002 | 08:38 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I would also add that the .001 is for making small adjustments
see if you can get someone to mic the crank b4 you order anything.
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
