400 block - cam removal difficulty
Old Apr 1, 2002 | 12:00 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Hey folks. I just got off the horn with a buddy of mine that is swapping a new cam into his 400 SBC. The block is a 1980 circa and has been bored .030 with an offset ground 400 crank with small journal 327 rods that give it .010" more stroke..... Comes out to a 417"
Anywho..... he said that he was having trouble getting the cam out. Both the old and new cams are rollers. The old one that was attached to its home was a single pattern @.050 230, .512" . He got it out to the second bearing journal (the cam that is) and it just stopped. He said it really felt like it hit something solid. So I suggested sliding it back in the rest of the way and trying again and turning it a bit more. He did that a few times and said there is just no way.... So after rechecking the obvious stuff (like forgettin lifters or the fuel pump pushrod) I suggested he turn the crank like 30* and give it a try.... So he does this and it slid right out.... So it seems that the crank was in the way of the cam sliding out some how.... ( I think ). I really haven't run into this on a SBC before but I haven't much experience with 400s. Is this a 400 thing? I dunno.... Not a big deal since he got it to go now but I just thought I would see if any of the heavy line gurus know about this.
Laterzzzzzz
Matt
Old Apr 1, 2002 | 02:06 PM
turningfast's Avatar
Yes, with 400 strokers. They make smaller base circle cams for this reason, even sometimes on 383's. A lot of people use rods with bolt on caps rather than the sock type nuts and bolts for a little added clearance. It only happens with large cams though.
Old Apr 1, 2002 | 02:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It happens with any cam, even a stock one. It makes no difference what the cam's lift is or whether it's a roller or whether it's a small base circle or anything else about it; it's the bearing journal hitting the side of a rod.
He needs to turn the crank a little bit, maybe 20°. Some of the rods are inside the "volume" that the cam normally occupies.
Old Apr 1, 2002 | 03:12 PM
Damon's Avatar
RB got it right. Happens almost every time on 400s and 383 stroker motors.
Old Apr 1, 2002 | 09:46 PM
Matt87GTA's Avatar
Kewl. I figured it was a 400 thing. Thanks folks
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
