Fuel Pump Problem
Old Apr 2, 2002 | 02:28 PM
HISTACKS's Avatar
Fuel Pump Problem
I'm trying to determine if the fuel pump is out on my '87 IROC. I tested the fuse and relay--both were ok. I then probed terminal G with a test light to make sure that it was ok, but could get no power. I finally tried a jumper wire from the ignition to the terminal in a last ditch effort to power the pump. Still nothing.
Any other ideas?
Old Apr 2, 2002 | 02:43 PM
rezinn's Avatar
If you're not getting power to the pump it obviously won't work, check everything you can on the way there. There is a connector under the car, near the differential. This is the last part you can check that sends power to the fuel pump. Sit under there and see if it is getting power while someone turns the key. If it gets power and your pump does not prime, it is probably bad. If you don't get power, work backwards from there.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
