Recommended fuel pump
Old Apr 2, 2002 | 02:59 PM
Farren's Avatar
I'm on my third fuel pump in 2 years in my 88 GTA and I think it's starting to go bad. (After it's driven for a long time it starts to make whining noises and the RPM fluctuates in sync with the whining.) So, when I replace it this time I want it to be the last time. Can anyone recommend a brand of fuel pump that will last?
-Farren
Old Apr 2, 2002 | 03:03 PM
rezinn's Avatar
Are you running the tank dry or using excessively high fuel pressure? Unless you got some no-name brand pumps, they should last much longer than that. If you just need a stock replacement, I would buy an ac delco. It may be a bit expensive, but mine has lasted a good 15 years.
Old Apr 2, 2002 | 03:59 PM
Farren's Avatar
Nope, I've never run the tank dry. I believe the last two pumps were whatever NAPA sells. (I just trust my local dealer....)
Here's what it does:
Generally, after a long drive and then comming to a stop I'll hear a whining in the back end. It starts loud and mid-pitch and then goes up in pitch and down in volume until you can't hear it any more. All the while the RPM is decreasing. Sometimes the engine will die, sometimes the fuel pump will "catch" and run for a few seconds before it starts all over again. Generally after a cool-down it will run fine again - for a while.
-Farren
Old Apr 2, 2002 | 04:50 PM
JAY87GTA's Avatar
I just bought a Walbro pump. Doesn't seem louder than the parts store one I put in and wasn't much more. I'm done with parts stores, I'm buying aftermarket everything if I possibly can. Later
Old Apr 2, 2002 | 09:19 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
http://www.jdsperformance.com/index....d=76&fcmd=item
Old Apr 2, 2002 | 10:09 PM
86maro305's Avatar
i just got a holley fuel pump from jegs. i haven't had it for very long but i heard good things about it. the only problem is that it is pretty $$$$. good luck in your quest to find the perfect fuel pump....:lala:
Old Apr 3, 2002 | 04:11 PM
GoFast91Z28's Avatar
Aftermarket parts aren't always best
Having been an ASE certified tech for a number of years- I can tell you from experience that many cars have been "fixed" by taking off some half-breed "Iwannagofast" junk and returning to a high quality replacement. One of the first things I look for when I find an ignition mis - are they Autozone plug wires. A-Z has some of the lowest quality crap I've ever seen. Alternator, starter, plug wires, fuel pump.....On the other hand I've seen certain AC Delco pumps, starters and alts go to h3ll real fast also. The point is --get pieces from a reputable source. Find out where local indepedent service shops get their parts. I'll bet they don't use A-Z. I'll also bet that you won't find any aftermarket electrical part that carries a lifetime warranty.
P.S. I am in no way affiliated with any parts store or aftrmrkt parts company.
Old Apr 3, 2002 | 05:53 PM
JAY87GTA's Avatar
A lifetime warranty doesn't do a damn bit of good when I have to spend 4 or 5 more hours changing the damn pump. I completley agree with you on the AZ junk though. I'm going aftermarket.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
