HEater core - in-line valve????
Old Apr 4, 2002 | 05:20 PM
Brett's Avatar
Ok, so I am putting the new non-ac box in the car. In order to do that I had to yank the hardline section of coolant tubing to the heater core. I planned to do this anyway, so not a problem.
First - I am *considering* totally bypassing the heater core and running a straight tube from my water pump to the radiator return. I'll have to make that call tonight.
Second - no matter what I decide to do, I need to get rid of the vacuum line correctly. The one I am talking about connected to the in-line valve for the heater core. Where does this vacuum line go? I assume to the heater controls in the dash.
How do I properly get rid of it?
Does getting rid of this valve and routing the tubes for constant flow mean that the heat will always be on?
Old Apr 4, 2002 | 06:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, the heat would be "on", but it won't be blowing at you. Coolant will just be allowed to go thru to the heater core.
This easy-to-crack Heater Diverter Valve started in '87. My '86 didn't have one. I replaced those factory steel lines with regular 'ol heater hose, and coolant's always flowing thru the heater core. The inside car temp might be a few degrees higher, but no big deal.
I'd say to plug the vac line up with a golf tee but I think you want something more technical
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
buckshot63
Sep 10, 2015 09:15 AM
