LT1 cam in a 305?
Old Apr 4, 2002 | 10:02 PM
89Irocker's Avatar
LT1 cam in a 305?
I want to swap in a LT1 cam into my '89 TPI 305, I was wondering if anyone had done this before and can tell me exactly what I have to upgrade to make this switch. One of my friends told me I need new 1.6 roller rockers or that my stock ones will float at higher rpms. Is this true? Also I heard I need to file off some kind of pin on the cam to make it fit right. ? Thanks for any help.
Old Apr 4, 2002 | 10:30 PM
iroc22's Avatar
Its been done quite a bit, hop on over to the TPI board and they can be more specific on the swap. I've never heard of having to swap the rockers, but the springs will need to be swapped
Old Apr 5, 2002 | 10:00 AM
Steve89GTA's Avatar
I know this much. LT1's have optispark (not a distrubor) so I don't know what guys are doing to their LT1 cams in order to drive their distrubors. Maybe you can add on a distributor gear or something??
Old Apr 5, 2002 | 11:43 AM
rezinn's Avatar
LT1 cams have gears on them. There is a pin at the front of the camshaft that will poke through your timing cover if you don't deal with it.
Old Apr 5, 2002 | 03:37 PM
Beefy89's Avatar
All you need to do is tap the dowel pin in about .300" on the front of the cam. On the LT1 cam, the dowel pin sticks out about .600" and I believe is used to drive the water pump.Tap it in so that it only sticks out .300" +/- .010.
If it won't tap in far enough,then grind it down to the desired length.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
