Vibration
Car: 86 Iroc
Vibration
Ok this is the problem...when cruising at a set speed the car gets this bad vibration...at all speeds and gears. When accelerating or decerating nothing...nice and smooth. Any idea's?
Car: 99 Formula
Axle/Gears: 342
Bent rim, wheel balance off, when I had a burnt plug wire the car would have a studder that felt like a vibration, just a couple things to check.
Car: 4
Engine: 6
Transmission: 5
It's probably not a wheel... they don't care whether the drive line has lots of force on it or not...
Check your pinion nut. It's probably backed off. That probably means you actually need pinion bearings, but chances are you can tighten the nut and it will be OK at least for a while.
roysatikas
Sep 22, 2015 08:15 PM
