Throttle Cable or?
Old Apr 6, 2002 | 02:09 AM
92'STOCKER's Avatar
Car: 92' Z28
Engine: 5.7
Throttle Cable or?
I know this sounds like an obvious question, but.....my car started staying at a high idle off and on. I looked at the throttle position and saw that it had around 1/16" gap when the idle was high. A light nudge and it returned to the correct position. Wiped the accelerator cable and added a light cable oil. The cable doesn't feel overly tight, but I still have the throttle position problem. A slight wiggle of the cable and the plate rotates to the correct position. I am not completely conviced that the cable is causing this. Anyone else had the same situation? I can only recreate the problem with the car on.
92' Z28 With 5.7 TPI
Old Apr 6, 2002 | 05:45 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most likely your throttle body is gummed up. Take EVERYTHING apart and clean in carb cleaner or any suitable degreaser. Very common problem on any chevy from a 4cyl., to an LS1.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
