Air/fuel ratio checking..?
Old Apr 6, 2002 | 02:45 AM
ORAY777's Avatar
I saw a oxygen sensor testor in a Mid America catalog. Can you use this to check air/fule ratio while on the fly? Anyways what are the numeric numbers that represent each fuel ratio change. Is it in ohms? For example 12:7 to 1 ratio would be equal to what number in ohms when checking oxygen sensor?
1991 Z28 1LE 5.7 auto.
Old Apr 6, 2002 | 10:26 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
not sure if you've checked this or not yet, but this tech article might be of some help:
https://www.thirdgen.org/newdesign/tech/o2tuning.shtml
Eric
Old Apr 6, 2002 | 12:10 PM
Guest
Guest
Posts: n/a
The stock o2 isnt much good for measuring things outside of the 'ideal' A/F ratio of 14.7:1. Its just not designed to work that way. A wideband o2 sensor is, but those are pretty expensive items. All reading the voltage off the stock o2 will do is give you a general idea of where you're at, it shouldnt be trusted as accurate.
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
