What do yall set you timing at
Old Apr 7, 2002 | 12:02 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I just set the base timing on my 91 Formula 5.7L. I set it at 6 deg btdc as the sticker under the hood recommends. I advanced it to 8 deg and even 10 deg without noticing too much difference. The shop manual says 6 deg btdc at 600 rpm. I didn't have a tachometer but the one on the dash said about 650 rpm at idle. Do I need to get a tach and connect it to the distributor like the manual says? What advantage would there be to setting it more advanced?
Old Apr 7, 2002 | 07:11 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You can safely run from 8-10* of timing without detonation. Advantages are better throttle response and a bit more "up top".
Old Apr 7, 2002 | 07:55 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I run 10* with no problems. I also run 94 octane at all times though so it may or may not detonate with lower octane fuels. Set your timing up to 8* and then take it for a spin. If it doesn't knock then keep setting it up a few degrees at a time until it does and then back out a few degrees.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
