code 36 Help
Old Apr 8, 2002 | 03:07 AM
onebadta's Avatar
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
code 36 Help
Hi i have an 89 GTA which i have been geting a code 36 on.....I have replaced:... MAF sensor...MAF power relay...MAF burnoff relay...Computer (probably used oh 6 of these) keeps frying them cant find any shorts or burt wires..........terminal D (tan wire) on on MAF burnoff relay grounded no blown fuses again no frayed wires or cut wires that i can find as of now can anyone help?????????????
Old Apr 8, 2002 | 08:52 AM
Vader's Avatar
1Bad,
Terminal 'D' is not used on the MAF burnoff relay. It is for the normally closed (NC) contact that should connect to nothing. When the system is deenergized you may be able to read some resistance to ground, but it shouldn't be 0. Something more like 200-250 ohms would be more appropriate.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
