water in oil on new motor
Old Apr 8, 2002 | 06:21 PM
BOTTLEDZ28's Avatar
Transmission: A4
i had a new motor in my z but had to pull it backout because it had no oil pressure after 20 miles. when i took the intake off, i noticed that some of the memaining oil left in the lilter valleys showed signs of water in it. it had the coffee with cream in it look. i also noticed the oil had a tint of dark green to it and metal dhavings in it. i didnt notice any leaks in the head gaskets and the block has no cracks in it. i also didnt see and white smoke from the tailpipes. my question is, I have an oil cooler, could this be leaking antifreeze into the oil filter somehow. where else could antifreeze get into the oil. my intake is not crakced either. this car is a 91z28 350tpi
Old Apr 8, 2002 | 07:44 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
maybe the intake gaskets didn't seal up. I've had nothing but trouble with felpro intake gaskets. So I buy all my gaskets at the dealer (about the same price) and I haven't had any problems since.
Old Apr 8, 2002 | 08:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
i only use gm gaskets. that is what was on it the first time. it they didnt seal then where would water come from.
Old Apr 8, 2002 | 08:30 PM
Joshua Leslie's Avatar
I second that, I had the same problem, turns out I forgot(actually, my buddy forgot to tigten the back 2 bolts on the intake as I let him put on the Edelbrock Throttle bracket) and it pissed coolant into the oil.
Old Apr 9, 2002 | 09:40 AM
BOTTLEDZ28's Avatar
Transmission: A4
does coolent flow through the intake or just the tb
Old Apr 9, 2002 | 02:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Coolant comes up to the intake base (sometimes flows as well) at the back of the heads; and into the base to the thermostat at the front of the heads. You should have coated the intake gaskets with sealant around those four holes. Any one of them can definately leak coolant right into the lifter valley. A cracked head at that point would leak coolant into the valley as well (never seen or heard of that, but anything's possible).
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
