Flow #s for stock 305 heads?
Old Apr 8, 2002 | 07:14 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Does anyone know the flow numbers for stock 305 heads? I'm currious to see what they get.
Rob
Old Apr 9, 2002 | 09:00 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Only have the flow numbers for the "081" '87/'91
305 heads. They flow 195cfm@.500 in.(182@.400") and 110cfm@.500 ex.
Other stock 305 heads with 1.84"in and 1.5" ex valves
will flow real close to this as this is very typical.
The last set of 305 heads I ported and flowed were
"416" castings and flowed 225cfm in. and 140 ex. through
1.94x 1.60" valves.
Should give you an idea of where you're at and the potential.
Old Apr 9, 2002 | 04:06 PM
Ride4ME's Avatar
Which 305 did these come in??
Definately not my lo3 swirl ports!!
Old Apr 9, 2002 | 07:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Would these be what was on my 87 LB9?
Old Apr 10, 2002 | 07:50 PM
F-BIRD'88's Avatar
Pull a valve cover off and look.....
Old Apr 11, 2002 | 12:11 AM
iroc22's Avatar
The 081 castings should be on your car. The 416 casting was a similar head that was used on the LG4/L69/LB9 305s (I have pulled these heads off of all these engines)
Old Apr 11, 2002 | 02:35 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
1.94x 1.60" valves.
Those number are almost an exact match for a set of Vortec heads.
Old Apr 11, 2002 | 05:44 PM
iroc22's Avatar
The only thing is Vortec heads have a more efficient kidney shaped combustion chamber so they will make more power, even tho the flow #'s are the same.
Old Apr 11, 2002 | 07:27 PM
F-BIRD'88's Avatar
The intakes were very simular but the vortec exhaust was better
unported than the "416"'s are ported.
Old Apr 11, 2002 | 08:02 PM
2000RATA's Avatar
Actually the Vortecs flow 240 on the intake.
Old Apr 11, 2002 | 08:14 PM
F-BIRD'88's Avatar
Mine didn't. They were 228@.500" We have gotten them over 240cfm with mild, easily done porting though.
All heads were flowed on the same bench.
Pac J
May 17, 2020 10:44 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Fireslash
Apr 11, 2016 06:43 PM
dusterbd
Sep 29, 2015 08:40 AM
toronto formula
Sep 10, 2015 07:31 AM
