Need help quick...what do I need to convert my dash to the 90-92 style???
Old Apr 8, 2002 | 07:52 PM
CamaroX84's Avatar
I have an 84 Camaro with the standard dash. I am putting in the 90-92 style dash into my car. I have already done a TPI conversion to my 84 if that makes any difference at all. I have a Painless VSS as well as a factory electronic speed sensor. What all do I need to make this conversion work? I am swapping over the entire dash, and I am concerned with the duct working, speedometer hook up, etc. ANY help would be greatly appreciated, as my parts car is getting taken away tomorrow, so I need to know everything I need to take. Thanks in advance.
Old Apr 8, 2002 | 10:20 PM
CamaroX84's Avatar
BTT please
Old Apr 9, 2002 | 01:59 AM
nesluopetan's Avatar
if your dash works now, then just switch them and it should still work. I just changed my whole car over, engine trans, etc and if the dash works after you to the conversion, then it should work when you switch dashes. You just unplug your dash and speedo cable, and plug it into the new one, it should be as easy as that, I didnt have any problems
Nate
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
zayne0
Aug 24, 2015 07:22 PM
Street Lethal
Aug 14, 2015 08:25 PM
