quick question before i go to bed, please answer asap. Im tired :-)
Old Apr 9, 2002 | 01:26 AM
nesluopetan's Avatar
ok, please answer asap. I currently have a 10 bolt, 28 spline, 3.08 posi unit in my camaro. there is 2 series and 3 series for these cars. on jegs it says 2 series is for 3.08 and numerically lower gears, and 3 series is for 3.23 and up. so If I want to change my current rear end into 4.10 gears, and keep the same posi carrier, all I need to do is buy a 2 series 4.10 ring and pinion set right? and everything will bolt up to my posi carrier? Please answer asap. I already have the bearings, and the posi unit is mint cond, so all i will need is jegs # 836-49-0009-1 right? I just need to make sure thats the right ring/pinion set for what im trying to do. Also, once this gets all done, if it starts to whine, what is the reason? is it because of bearings not put in right? is it because of gears not calibrated right? what? thanks guys.. please answer asap.. im awake awaiting answers.
Nate
Old Apr 9, 2002 | 01:33 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
YEP
ya, you only need the 4.10 ring and pinion setup for a 2 series carrier, it is a thicker ring gear, whinning would mean improper gear pattern setup............
Old Apr 9, 2002 | 01:35 AM
thank you.. thats what i needed to know
Old Apr 9, 2002 | 01:39 AM
anyone know what RPM i will be running at going 60mph with my TH350 trans and 4.10 gears? can someone tell me really quick.. is there a huge noticable diff between 3.73 and 4.10?
nate
Old Apr 9, 2002 | 03:39 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Assuming your tire radius is 13"...
3.73...@60mph...2892rpm
4.10...@60mph...3179rpm
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
bamaboy0323
Aug 15, 2015 07:20 AM
jahblah
Aug 12, 2015 05:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
