400 small block 2 or 4 bolt
Old Apr 9, 2002 | 06:51 AM
pokes87iroc's Avatar
is a 2 bolt as strong as a 4 i read in hot rod it was and i want to make sure cause i can get a 2 bolt 400 for like 50 bucks any help would be nice thank u very much
Old Apr 9, 2002 | 07:14 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
DUDE! Get the 2 Bolt - FAST! 400 block arent as common as 350's, and they are usually more expensive. 2 Bolt 400's are stronger than the 4 Bolt versions due to the way the bolt holes were tapped. In the 400 bolck, the extra 2 bolts run throgh the block webbing, and create problems with its structural integrity. If yuo want a 4 Bolt 400, your best bet is to get a 2 Bolt, and have it machined for aftermarket 4 Bolt maincaps (Miloden sells them, and I'm sure some others). Hurry up, go now, pay the man and bring that block home!
Oh, and MAKE SURE that the block hasnt already been bored out. If it has, make sure it has only been bored out .030", and that the cylinder walls are clean and not all scuffed up. Any more than a .030" bore on 400's is risky business, or so I have heard. You may want to do soem more research if it turns out this block has been bored more than that.
Old Apr 9, 2002 | 08:27 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Either the guy who is selling the block is a moron or there is something seriously wrong with the block. 2-bolt 400 blocks are becoming harder and harder to find so I'd pick it up in an instant but be sure to check it out good.
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
