Installing a vacuum advance distributor
Old Apr 9, 2002 | 07:54 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Can I install a regular vacuum advanced HEI in place of the stock distributor on my LG4 and still have the ECU and CC q-jet work right?
Old Apr 9, 2002 | 08:03 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The carb will work, but not properly, neither will your TC lockup. And you'll get about 10mpg , happened to me when I installed the 350.
Old Apr 9, 2002 | 10:12 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Thanks, that's kinda what I figured, but it never hurts to ask.
Old Apr 10, 2002 | 01:03 AM
iroc5speed's Avatar
after the swap you can go ahead and install that edelbrock carb you've always wanted....they're only 200-250
Old Apr 10, 2002 | 01:16 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I was going to say, but yes Mark is right.
The ECM needs to see the dist. there, pulses and such, I guess.
But go ahead and get the aftermaket card with the non-CC dist.
Install the manual lock-up switch, and your good to go with out the ECM.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
cstrobel65
Aug 15, 2015 10:19 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
