Car stalls out
Car stalls out
I have a 87 Trans Am with a LG4 engine. The car starts fine but when I put the car in drive or reverse the RPMs go up and down for a few seconds and the car stalls out. Even after the car warms up the car still stalls when in drive or reverse. I had the carb rebuilt, the problem went away for a couple week and the it came back. Can anyone help me
Car: 89 RS
Transmission: TH350
Is the Idle set right? How long since a tune up? Fuel filter is probably the first thing to check. I dont think a vacuum leak is the problem, that would more than likely raise the Idle. But check anyways. I found the best way to check for vacuum leaks is with a torch, just not lit. The hand held propane torches, the ones plumbers use. You know.
