fan not working
Old Apr 10, 2002 | 10:08 PM
SpeedPhreak's Avatar
fan not working
ok.. here is the deal.
car has been overheating. so i did a thermostat change & a rad flush.. still over heated. then i noticed that the fan isnt turning on.
i found that the fan works if i hook it directly to the battery.
since i was already 10hours late leaving for vegas from colorado (also did brakes, oil, new washer pump, other minor things).. i just ran a wire w/an aligator clip from the fan positive wire to the battery.
so what can b causing the fan not to turn on? sensor/switch? where is it.. heads?
thanx for the time.
Old Apr 10, 2002 | 10:18 PM
86IROCZ's Avatar
since you know that the fan runs start by checking the fan relay. it should be near the battey stuck to the radiator support.
Old Apr 10, 2002 | 10:44 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
The switch that measures temp and causes the fan to kick on is on the passenger side of the engine right below the plugs. Maybe your wire is toasted, loose connection or the switch is bad. Make sure your car isn't hot if you need to change the switch...coolant is behind it.
:hail:IROC-Z
Old Apr 10, 2002 | 11:18 PM
86IROCZ's Avatar
The temp sensor near the plugs is only for the temp gauge on the Insterment panel. The one for the ECM (that turns the fan on and off) is on the front of the engine near the water pump.
Old Apr 11, 2002 | 08:28 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Take a look at this thread. There's even a picture with it.
https://www.thirdgen.org/techbb2/sho...+on+passenger+
I hate to say it, but...told ya so.
:hail:IROC-Z
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
