how to machine Push rod guides on and 91 305 head ?
Old Apr 11, 2002 | 12:35 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
The 91 305 head has the round push rod guides
I was just going to use my carbide proting bits to enlarge the holes for 1.6 rr's
The guides are not a contact area due to the Self adjusting Rockeres
So I dont see the problem by just doing it by hand
Has anyone else done this? or see a problem with it ?
How much will the angle be changed ?
Thanks for any input
Old Apr 11, 2002 | 04:16 AM
ede's Avatar
ede
there is a drill guide made for this, then you use a hand drill with the guide, real simple and it doesn't cost much, look in comp or lunati catalog for it
Old Apr 11, 2002 | 09:41 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
I actually bought the Comp cams Louis Tool and it actually turned out to be for the Sloted style heads pre-89 I think
so they make two different type tools?
thanks
Old Apr 12, 2002 | 01:43 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
anyone else please?
I really dont mind what it looks like ...so I dont think it will be an issue as long as I make the clearance
think it's ok to do by hand
Old Apr 12, 2002 | 03:20 AM
Jester's Avatar
I think with the heads with the round pushrod holes you shouldn;t have to touch anything on them, assuming you're still using self guided rockers. Some older slot-style heads have problems, but you shouldn't.
If you're in doubt, put on the rockers and turn over the engine a few times by hand..see if the pushrods rub at all.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
