What do you think I should set my fuel pressure at??
Car: 85 TA
my mods are listed below and im getting my car dynoed next week...ive run a best of 13.5 with 52 psi at the track but thats with no messing with the fp. Keep in mind this is with stock #19 injectors. thanks
I kept my fuel pressure in the 43-47 range on a 350 with 24lb inj.
Car uses a stock 85' 305 computer.
I was running in the low 13 range 13.0 best.
Messing with fuel pressure never helped me. Some swear by it.
Also running to much FP can cause the injectors to lock up.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: What do you think I should set my fuel pressure at??
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
