Serpentine conversion help.
Old Apr 12, 2002 | 04:04 AM
PerthZ28's Avatar
I am converting to the serpentine system and need to know where all the black brackets [support struts] go. I have like 5 of them! I know that 1 goes on the back of the alternator to the 1st exh manifold bolt but what about the others?
Old Apr 12, 2002 | 10:05 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
supports what supports?
i don't have any one these on my motor and have never had any problems.
Old Apr 12, 2002 | 04:50 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I think I used three. Car's torn apart and I kinda forget. I had one coming from like the third exhaust manifold bolt back from the front on the passenger side up to the back of the AC condenser. On the drivers side there are two that come from the first exhaust manifold bolt and attach to the back of the alternator and the power steering pump. I think they vary from year to year too. HTH's.
Old Apr 12, 2002 | 05:19 PM
89WS-6's Avatar
Why would you want to convert that? I thought the 3 belt system was more efficent??? Could be wrong.
Old Apr 12, 2002 | 07:30 PM
rezinn's Avatar
How is using three belts instead of one WITHOUT a tensioner efficient? Removing two belts just to change one isn't my idea of efficient. They are a pain in the ***.
Old Apr 12, 2002 | 08:59 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The other bracket is for the AC compressor. When installing hedders, I removed the brackets, and didnt replace them, and have had no problems.
Old Apr 13, 2002 | 02:13 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Only 3 belts? How come I have 4? Theres one that goes crank to air pump, another that goes crank to power steering pump, then one that goes water pump to alternator, then a big one that goes crank-power steering pump-ac compressor.
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
Numbah-1
Oct 2, 2015 08:27 AM
