Oil Pan Gasket Replacement
Old Apr 12, 2002 | 01:19 PM
gruveb's Avatar
Car: 1989 IROC-1
I've never replaced one on these cars....Is it pretty much unbolt it, clean it, replace the gasket and throw it back up there, torque it and go?
Only reason I ask is because I did one once on a cavalier and it turned out the engine had to be lifted to do the oil pan.
Every engineer should be a mechanic before becoming and engineer!!!!
Old Apr 12, 2002 | 01:28 PM
Jester's Avatar
You have to jack up the motor and have the crank rotated to the right spot to get it out.
Cut 4 6 inch long sections of a 2x4 before hand. Use them to put inbetwen the motormounts when you jack the engine up to hold it up when you remove the jack, 2 per side. Then..I wanna say the crank has to be at 6'oclock to get the throws out of the way..but I can;t remember that for sure.
Oh yeah..and be sure nothing will crunch on the firewall when you jack it up....like the distributer.
Old Apr 12, 2002 | 01:49 PM
gruveb's Avatar
Car: 1989 IROC-1
Where do you jack the motor up at?
Old Apr 12, 2002 | 01:51 PM
Jester's Avatar
take out the motor mount bolts and put the jack cup under the balancer.
Old Apr 12, 2002 | 02:39 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I hope you're not serious.
Old Apr 12, 2002 | 09:07 PM
Joshua Leslie's Avatar
Christ, I though I was a hack!
dude, dont be a hack, dont jack it up on the balancer use wood under the mounts, that is not safe.
Here is the correct way:
1.Remove distributor cap
2.remove motor mount bolts
3.remove exaust manifolds/headers(if nescesarry, on headers it for sure will be.
4.rent an engine hoist....Pep Boys does it for free...just give them 250$$ deposit, and they give you the hoist...then you give the hoist back,and they give you the $$$ back
5. remove 1 intake manifold bolt on each side of the engin, on opposite sides, at the corner, put a longer bolt in there, and a chain link through the bolt.
6.remove carbeurator..if necessary.
7.Jack the engine up..slowly
I was able to do it this way without unbolting the engine from the tranny, I cant remeber, buy you may have to loosen or remove the tranny mount.
Now..as for getting it to seal...good luck
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
