fuel pump won't stop
Old Apr 13, 2002 | 01:21 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
What would cause the fuel pump to not stop running? I finally had to disconnect my battery. I started for the car first time and it ran fine (engine swap TBI to TPI), but now fuel pump will not stop running.
Old Apr 14, 2002 | 11:15 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
you did a TBI to TPI swap? I would first recheck your wiring, the relay could be sticking, and also I have seen on GM's if the oil pressure sending unit is bad, if its full of oil or something, it will short out inside, and will back feed and make the fuel pump run all the time. I had this happen to a lumina at work one time, it drove us nuts trying to figure it out. hops this helps some.
Glowsock
Jul 24, 2025 03:15 PM
jklein337
Sep 19, 2018 06:23 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
